Re: New plumbing run to existing stack
Posted by Gary Swart on February 12, 2002 at 12:10:31:
In response to Re: New plumbing run to existing stack
Steve, always use the widest radius possible in a drain. When cutting the cast iron, make triplely sure you have it WELL secured above. That stuff is heavier than sin. I just replaced my cast with ABS, and while I thought it was clamped pretty good, it wasn't. Thank God no one was under it when it came down! I'd cut it where it was the easiest to reach and still maintain the 4/12 drop. Can't see that a little more drop would hurt.
