Re: Need to add drain for sink in garage
Posted by Gary Swart on February 11, 2002 at 00:24:13:
In response to Re: Need to add drain for sink in garage
If there is sufficient drop for the drain, 1/4" per foot, you can do that. What kind of drain pipe do you have? If it's plastic, then I'd try to figure out how to access the drain below the clean out and use a saddle fitting to tap into the line. If the sink will be close to the main drain, you won't need to vent, but if it's any distance, you will need to vent.
Replies to this post
There are none.
