| Posted by hj on February 10, 2002 at 21:29:32: | |
| In response to Re: flange to high above the floor line | |
The too high flange is an easy fix, if you are a plumber. Break it off and install a new one. You cannot attach a PVC flange to cast iron. If you want to move the opening then you can cut off the toilet pipe and install a shorter piece of PVC with a flange. Or you can get a toilet that fits the rough in you have. : I am remodeling my bath room and I can see a problem right off. : The bath room floor is real bad, the tile is all broken is and must go. : My problem is that the inlaid tile and cement is 1.5" and the flange in on top of that. I do not want to build the floor up the 1.5"'s for that will leave me .75" higher than the hall floor. : Is there a way to take out only part of the old cast iron flange and lower it with PVC??? : The old TB, also set 2" from the wall, and would like to move it closer/ : Thanks
| There are none. |
