Re: island vent - please help...
Posted by Gary Swart on February 10, 2002 at 14:06:57:
In response to Re: island vent - please help...
The spring loaded inline vent is simple and is what I'd do. In fact, I've been using one for several years on my kitchen drain without a hint of problem. That said, if it's against code where you are, and especially if the work has to stand inspection, then the alternative route is what to do. It sounds like a pretty straight forward operation, so if you're at all in doubt, run the line. Remember, a vent line can have sharp corners if necessary, and it doesn't have to be huge. I just finished removing a 4" cast iron vent stack! Replaced with 3" ABS and, that's more than I need.
Replies to this post
There are none. |
