Re: home shower stall
Posted by edj on February 09, 2002 at 22:23:23:
In response to Re: home shower stall
here we put a rubber liner on the floor and up the walls including the dam.Its all one piece.We use a shower strainer that is designed the clamp over the liner allowing any leakage to flow down the drain.These strainers are also adjustable to the depth of the base. The base is then poured,and the wallboard goes up.Use good quality waterproof wallboard.The tiles glue right on to the board and then grout
Replies to this post
There are none.
