| Posted by edj on February 09, 2002 at 21:40:04: | |
| In response to Re: Vibrating pipes | |
: My water pipes have started to vibrate when the water is turned on anywhere in the house. I have shut off all the valves with the exception of the main valve which also controls the shower pipe valving. When the water is turned on low, the vibration is very severe. Opening up the water valve on the sink faucet seems to soften the sound but it does not go away. The worst : case is the basement toilet filling, but it still occurs with the toilet valved out. The house is 25 years old and I have never experienced this problem before. How do I correct it or tract it down Loose washers in your shut off valves and your taps can sometimes cause this problem.I would |
| There are none. |
