Water bubbling from overflow drain
Posted by Girish on February 09, 2002 at 12:45:12:
Hi,
For the past 8 months there has been a slow
trickle of water from my front-yard water overflow drain. The leak is worse early in the morning and then
reduces to a slow steady trickle throughput the day. My association property manager tells me the drain is for the back-yard and front-yard excess water overflow purposes.
I tried shutting off the main water inlet valve
and the water meter still keeps rotating slowly.
Any suggestions?
Thanks
Girish
Replies to this post
There are none.
