Re: Jacuzzi Whirlpool
Posted by hj on February 08, 2002 at 22:34:30:
In response to Re: Jacuzzi Whirlpool
Since there is no angled tee, you may have to use more than one of the overflow beveled gaskets.
: I'm trying to install a Torino 6 Jacuzzi Whirlpool bath and when assembling the trip drain assembly, the way the elbow sits on the tub makes the overflow tube go down at an angle instead of 90 degrees. There is an overflow gasket between the tub and the overflow elbow, but it still comes down at an angle so that it will not connect correctly with the waste tube. How can a person make the tube come down straight, or do you need an angled tee to connect to the waste tube?
Replies to this post
There are none.
