| Posted by hj on February 07, 2002 at 21:46:39: | |
| In response to Re: Drain pipe-ABS/ | |
Why would they carry fittings but not pipe? Some places allow the mixing and others either do not permit the transition cement or only allow one joint where you change to the different material. : I am moving a sink drain in a concrete basement floor. The existing pipe is ABS. I can't seem to find any ABS pipe but I can find ABS fittings. Can I use PVC pipe to connect to the ABS pipe with a universal cement? : My hardware store showed me that a
| There are none. |
