| Posted by hj on February 06, 2002 at 23:24:29: | |
| In response to Re: Checkvalve | |
Without the check valve all the water in the pipe will drain back into the sump. In a worst case situation, that might be enough to make the pump start again, if the sump is small enough. : I have a sump pump discharge with a checkvalve about three feet above the pump. The 1-1/2" discharge line with a 20' run has an air gap at the end where the water is dumnped into a 3"x6' vertical line going to a leech field perimeter drain. Assuming that the purpose of the checkvalve is to prevent backflow and that the possibility of back flow is almost zero, do I need to have a checkvalve? I would like to eliminate the checkvalve to reduce the hammer I am getting when the pump stops and to drain back the water that is being trapped in the negative slope the plumber built in.
| There are none. |
