| Posted by Gary on January 23, 2002 at 03:33:52: | |
| In response to Re: Running water to detached garage | |
For a long run such as you have, I'd recommend 1" copper. I believe the grade is type K, but check that at the supply house. You will lose all pressure if you use small diameter pipe. I don't think plastic is suitable for underground potable water. Learn to solder, it's not hard and since the pipe will be buried, it doesn't have to even look pretty. |
