| Posted by hj on January 21, 2002 at 08:42:31: | |
| In response to Re: Bathtub overflow drain. | |
Liberal amounts of WD-40 sprayed down the overflow pipe and a lot of prayers are the best, and only, way to get it out without opening a wall and disassembling the drain pipe. : Hi Terry, I am trying to remove the old overflow assembly (lever type) on a bathtub. However, it is stuck and will not budge! I only removed the overflow plate and tried to pull the old assembly out. I have not removed the strainer in the bottom of the tub, it is still intact. Any help will be much appreciated. I have never done this before, and I am ready to scream!
| There are none. |
