Bathtub drain
Posted by Earl on January 19, 2002 at 11:05:19:
I've got an odor definately ONLY coming from the bathtub drain. The metal drain at the surface of the fiberglass tub is completely corroded and the black material underneath the crome is partially exposed and somewhat soft.
So does anyone know the basics ( Is it 'only' screwed down into place? etc. )on how to replace the crome drain without removing the tub surround?
The it possible that it's ONLY coming from the corrosion process? What is your most likely guess?
Replies to this post
There are none.
