Re: American Standard Vent Away Toilet - unplugging
Posted by Salty on January 18, 2002 at 22:01:54:
In response to Re: American Standard Vent Away Toilet - unplugging
I wouldn't use a plunger beacuse you might damage the mechanism. Use a closet auger, they work better anyway. If a closet auger dosen't work, remove the toilet and use a regular snake. : I have two American Standard "Vent Away" toilets that I cannot unplug using the standard plumber's helper. The shape of the outlet hole in the bottom of the bowl is not circular and that prevents a tight seal for the plumber's helper plunger to do it's job. Is there some other device or technique for unplugging this toilet?
Replies to this post
There are none. |
