Re: low water well pressure
Posted by Frank A. Magnelli on January 13, 2002 at 20:30:03:
In response to Re: low water well pressure
: I live in the country and have a water well, my question is this , how much air pressure should my pressure take have in it and will this help my waterpressure any , I've change my pressure switch and have adjusted it to specs but still not much pressure. Any advice would be highly thankful. Your well pump should kick on at 30lbs. and shut off at 50lbs. It could operate at 10lbs higher respectivly. Whatever the low side is on the well pump side you subtract 2lbs and that is how mich preasure you should have in the tank.
Replies to this post
There are none. |
