We have had an ongoing problem with the caulk line between our cheap plastic/fiberglass tub surround and cast iron tub, and some of the greenboard behind has mildewed. We plan to replace the greenboard and tub surround but we're a little stymied by the choices and the cost. We don't want the maintenance headaches of ceramic tile. A contractor friend says we would probably have the same problem with the caulk line with a new plastic/fiberglass surround even if we install one of a higher quality. We're looking at cultured marble but are finding the cost is a bit more than we wanted to spend, although we'll go with it if less expensive materials are incompatible with a cast iron tub. Any experiences or opinions on which material would work best in the long run?
