Re: Roughed in Plumbing - Stub Plumbing
Posted by hj on January 11, 2002 at 21:50:48:
In response to Re: Roughed in Plumbing - Stub Plumbing
Yes, no, and maybe. Since the trap needs to be accessed to make a final connection, there is usually an annular space or box around the riser. For this reason, the trap could be left off and then the trap installed, once a definite spot is determined where it has to be positioned, once the plumbing is completed.
: When stub plumbing is installed when a house is being constucted shouldn't a p trap be installed so the cement doesn't have to be broken up when fixtures are eventually installed? Isn't that the purpose of having stub plumbing installed at construction time?
Replies to this post
There are none.
