| Posted by hj on January 11, 2002 at 01:07:14: | |
| In response to Re: Do it yourself copper plumbing | |
Clean the tube and fittings, use a proper flux, and heat the joint properly. If you do all these you will have few if any leaks. : What is the secret to sweating copper tubing connections to get a perfect seal?
| There are none. |
