| Posted by No Leaks on January 10, 2002 at 22:42:15: | |
| In response to Re: hot water problems | |
: If I get a call like this I would change both heating elements. While they were out I would see what shape the dip tube was in ( its the tube on the cold water in let that brings cold water to bottom of heater). Could also be bad aqua stats. But to be honest with you since your water heater is 17 years old I would advise that you juts replace it since the tank will propably be leaking in the near future
| There are none. |
