Re: Installing new water heaters
Posted by Rich on January 08, 2002 at 17:01:29:
In response to Re: Installing new water heaters
: I have this week installed 3 water heaters in the same location all leak!!! What does this indicate????
The chance of 3 heaters leaking after installation due to a defect is small. I hate to suggest it, but this could be a problem with the "insaller". If you are using too much heat when you connect the in and out lines, damage could be done to the tank. The best installation is to use threaded connectors, and not subject the tank to any heat at all.
Replies to this post
There are none.
