| Posted by hj on January 05, 2002 at 08:21:01: | |
| In response to Re: bathtub faucet steady streaming out cold water | |
I am not sure if your brother repaired the faucet or did a cosmetic thing to it. If he cut the stem off, it is possible that it is too short and the handle is hitting the metal cover on the wall and cannot turn far enough to shut itself off. If that is the case, you will have to loosen the screw on the handle so it can come off a little way and shut the faucet off. Otherwise, you need to repair the faucet or, more likely, replace the stem. : Hi There, my name is Lynnette and I'm in dire need of assistance. I have a bathtub faucet that has slowly been leaking then tonight it turned into a steady stream, like it's not even shut off. The only way to make it stop for the night is to turn the water off, unfortunately. It's not the handle (that's not stripped), my brother just replaced the handle about a month ago and when he did he had to 'saw' the pipe down a little bit? Does that make sense? I have NO idea what he meant by that. He just did it and said it needs to be 'fixed' soon otherwise it's going to turn into a steady stream. Well, it has.
