| Posted by Jerry on January 04, 2002 at 21:49:33: | |
Hello, sure hope you can help me. I have a bladder type pressure tank,that developed a bladder leak. I removed the bladder from the tank through the small port in the bottom of the tank. In order to remove it, I had to cut it in pieces as I pulled it out. I purchased the new bladder, and need some advice on how to get it into the tank through the small port hole. Thank you
| There are none. |
