| Posted by More on December 27, 2001 at 20:58:38: | |
| In response to Suspended garage not Engineered for added weight of room | |
The suspended garage isn't engineered to also carry the weight of the room you are adding, and then the furniture, and able bodies who will occupy it. You are creating a potential disaster if the room you are hanging under the suspended garage isn't transferring it's own weight through the bearing weight to the ground. Concrete anchors are not designed to carry live loads, and certainly glued ceiling joists are out of the question. You'll need to construct footings or Piers to carry the live weight of the new room transferred to firm stable soil through outside bearing walls. These outside walls are constructed with "pockets" for the ceiling joists to rest upon headers, (or top plates) which can be nailed or screwed to the framing in the traditional manner. Be advised that you are also creating a FIRE TRAP by the effect of a chimney that cannot be accessed below the suspended floor of the garage, which will likely house flammable fuel, oil, solvents, cars, snowmobiles, lawnmowers, etc. since your cieling will likely contain electrical conduit, lights, heaters, plumbing, vents, computer and alarm wiring : I have a suspended garage under which I'm building a room. I want to install a sheet rock ceiling, but I'm unsure how to install the ceiling joists. The room is 10'x12' using wood 2x4 construction. The best option I can think of is to use concrete anchors to suspend 2x4s between the walls. Any suggestions on types of anchors, if this will support the weight of sheet rock, etc. ? Thanks.
