| Posted by hj on December 27, 2001 at 09:03:27: | |
| In response to Re: running water in the toilet | |
You will have to determine what is keeping the ball from rising to the level that will shut the valve automatically. That can only be determined by someone actually looking into the tank while it is refilling. : hi just wondering i replaced the entire inside of the holding tank of the toilet ,, and after someone flushes the toilet and the tank refills to its proper level.. the water runs on continuously,, i actually have to pick off the top of the tank and pull the ball up and that will stop the water from running on.. thank you for your time and effort.
| There are none. |
