Pressure Limiters
Posted by michael brett on December 26, 2001 at 21:20:33:
I have a brand new well with both a ton of water volume and pressure.. I have a constant supply pump that maintains 80psi @ 25gpm. I have great pressure and volume every where except in the showers. I have removed all of the flow restricters from the shower heads. Can there be flow restricters in the shower valve body itself? and if yes is there any way to remove them with out a solder job.. I seem to be able to do everything except solder good. By the way my shower valves are both singe handle delta's.
Any help would be apreciated!
Replies to this post
There are none.
