Re: toilet bowl water level
Posted by hj on December 18, 2001 at 09:07:46:
In response to Re: toilet bowl water level
a sponge, cup, or wet/dry vacuum will all remove the water
: Hope someone can help with an answer. Our water softener didn't work correctly for a while and as a
: result, one of the toilet bowls has a lot of rust marks. Is there an easy way to lower the water level in the
: bowl so I can scrub it out with a rust remover? Thanks.
Replies to this post
There are none.
