| Posted by hj on December 17, 2001 at 08:43:39: | |
| In response to Re: water softner install | |
You will install it in the same location, but it would be very unusual if the piping did not have to be revised for the new unit. Be certain that you know which pipe is the inlet and connect it to the softener properly. : Can a novice plumber like myself,install one of these? I already have an old one(20+ years old)which has been turned off now for 2 years. Could I simply re-use the connecting water source? : Thanks!!
| There are none. |
