| Posted by hj on December 16, 2001 at 09:57:09: | |
| In response to Re: Metal Marked Toilet | |
A pumice stone from a swimming pool company may work. You should have used a closet auger which has a rubber shield to prevent that from happening. : I have a Briggs toilet. Recently I used a wire snake to clear a clog. In doing so I marked the porcelain. I tried cleanser and steel wool to remove the scratches. All I succeeded in doing was to make it worse. Any ideas on how I can restore the finish and what should I have done originally to avoid scratching the surface. Thanks!!
| There are none. |
