| Posted by hj on December 16, 2001 at 09:54:17: | |
| In response to Re: Increasing water pressure | |
If you increase the air pressure (how much depends on what the starting pressure is), and it has to be done while the tank is empty of water and on an open system, you will not increase the water pressure but will make the pump run more often. To increase the pressure you have to adjust the control switch. : I notice that my 'ho
| There are none. |
