Route of Washer Drain on Slab
Posted by Will on December 15, 2001 at 16:06:53:
Hello, I have a small home built on a concrete slab. I want to install a washer/dryer in a space that has water supply, but no drain. There are doorways on either side of the room that prevent running a drain through the walls to reach the other waste plumbing in the house. The machine will be on an outside wall, but running a drain around the outside of the house to connect to the sewer line would be expensive, as would be cutting up my concrete slab for a drain in the floor. Can the water be pumped OVER a doorway to reach a drain? Any other ideas? Thank you!
