Re: Below Ground Trap Under Toilet
Posted by hj on December 13, 2001 at 08:09:01:
In response to Re: Below Ground Trap Under Toilet
: There seems to be a trap in the concrete slab below our Master Bath and Guest toilets. I can just reach it when the snake is fully inserted and can usually clear the clog. Will replacing the toilet installed in 1993 reduce or eliminate clogs or do you think something is stuck in the traps?
Replies to this post
There are none.
