Re: sewage pump
Posted by hj on December 12, 2001 at 08:14:19:
In response to Re: sewage pump
If they are being described properly, then yes. The function is in the construction, to handle solid wastes, not the name. If it is not a sewage pump then it should be a sump pump, which has a completely different construction for a non-solid waste use.
: Is a sewage pump and a sewage ejector pump the same thing?
Replies to this post
There are none.
