| Posted by RJ on December 10, 2001 at 13:15:09: | |
| In response to Re: Clean out clogged water lines | |
: I have copper pipes attached to city water system. Water has not been used for several weeks. Water flow now extremely low. Checked flow at meter and pressure is ok coming into house. Copper pipes must be plugged up. Any way to flush them out. Talking both hot and cold. Have removed areators.. No galvanized pipes/fittings in system. : Regards I would recheck the valves at the water meter by taking the line apart and visibly checking to see if they are open completely, checking the house side should be easy but checking the street side will require shutting off the service at the street. |
| There are none. |
