| Posted by Clyde on December 07, 2001 at 13:59:12: | |
| In response to Re: Toilet installation | |
: : I'm replacing a Kohler toilet with a Toto toilet. The circular base that attaches to the floor under the toilet is raised higher than it should be. The toilet does not sit solidly on the floor, but rocks a little bit because it is resting partially on the raised base. Is there a simple solution to this problem without tearing out the drain and lowering the base? : : Thanks, : : Clyde H. : Clyde, Thanks. I going to try to the full size shim. |
