| Posted by hj on December 05, 2001 at 08:12:11: | |
| In response to Re: leaking water heater drain | |
Remove the white handle and a standard 3/4" female hose faucet will screw onto the pipe. To remove the handle, turn it counterclockwise for many turns and then turn it clockwise while pulling on the handle. : Can a leaking water heater drain (large white hand-turned valve) be repaired? How? Or does it have to be replaced. Thanks
| There are none. |
