| Posted by Rob on December 04, 2001 at 18:42:13: | |
| In response to Re: Natural Gas Pressure | |
: Your gas supplier's regulator will normally supply you with about 7" w.c. (water column. 1 psi = 27" w.c.) : : I am installing a tankless water heater and the required gas pressure is: : : minimum - 7" w.c. Thanks hj. You responded faster than PG&E. |
| There are none. |
