Showerhead water flow stops coming out
Posted by Jesus Alaniz on December 02, 2001 at 19:31:42:
First of all, I have a tub/shower. The water flows through the spout without a problem, but there are times that when you push up the handle to turn on the shower that the water will not flow through the shower head. Other times, you can be in the middle of the shower and then the water flow will stop. At times it will make a noise before it shuts off, but other times it just stops without advance notice. But when you turn the handle down to turn off the shower, water flows through the tub faucet without a problem. Help!! There's nothing worse than having to take a shower and it stops! Any ideas will be welcome.
Replies to this post
There are none.
