Kohler Pedistal Sink Replacement
Posted by Bill on December 01, 2001 at 18:28:55:
I just purchased a Kohler pedistal sink to replace the existing one, which I started to install. The drain for the sink is through the floor, rather than the wall. I found out that Kohler doesn't make a pedistal sink which drains through floor, what are my options? Can a drain-hole be drilled through the Kohler pedistal without damaging/cracking/destroying it? Should I try to locate another pedistal from a different manufacturer? Rerouting the plumbing could be labor intensive and messy....any advice would be appreciated!
Replies to this post
There are none. |
