| Posted by More on November 29, 2001 at 23:14:48: | |
| In response to Re: drain line | |
When the vanity top is installed, the sink drain will be how many inches below the top? When the vanity drain is installed, will it have a "Pop Up" drain opener attached? The hardware for the sink drain will dictate the distance below the vanity top that you can begin the drain and vent piping. Will the drain have a clean out at that point, or will you clean the drain by disassembling the "P" trap? Will the vanity have a floor of its own that your drain will need to pass through? How much room inside the vanity cabinet will be available for plumbing make up? : how many inches up from the floor should i stub in my drain line for the vanity?
| There are none. |
