| Posted by More on November 29, 2001 at 22:49:23: | |
| In response to Re: Looking for custom length brass pipes (approx 2"). | |
Contact a reputable LICENSED plumber in your area and ask for an estimate to custom thread the nipples you require. They will be happy to accommodate you. Merry Christmas : I had a three body sprays put into my shower (Grohe). Now that its finished, the 3 sprays are not uniformly protruding out from the wall. it seems that they were not all roughed in the same way, so there is well over 1/4" variation in their depth. Its very noticable as the Grohe part has a skirt that slips over a shoulder, and you can see the difference in the space between the shoulder and the skirt ring. : The sprays are 1/2" NPT. The connect with the plumbing behind the wall (as a normal shower head would) with (I believe) a 2" long double male NPT threaded pipe. : All the plumbing supply stores around me only offer these extensions in 1/2 increments. : What I am looking for are two custom pips so I can get a uniform look to the sprays. Can anyone suggest where I could get customer length pipes made? : David
| There are none. |
