| Posted by Jeff on November 29, 2001 at 21:08:15: | |
| In response to Re: No heat in radiators | |
: Check the thermostat valves, take off the thermostat end and make sure the rubber valve is moving (a little screwdriver and knock it loose if necesary). Is is probably stuck closed. : (At least that is what happened to me in England.) : Jeff
| There are none. |
