| Posted by Joel on November 29, 2001 at 02:19:41: | |
| In response to Re: Tankless water heaters | |
I have a Rinnai Continuum. I would recommend this unit if your house has only 1 or 2 bathrooms. The flow rate depends entirely on the input water temperature and the seleted output water temperature. For 54 degree F rise (from 66 to 120) this unit can provide 6.2 GPM, that is 3 shower heads (2.5 GPM) and 1 faucet. I like to simply selecet a 108 degree shower with the handy control unit (you can wire 3 of these) and turn on only the hot valve. No water temperature fluxuations at all. If I select a higher temperature, and mix for the shower, and someone opens several hot taps full force, I would notice, but this is true for any water tank as well. Select the right unit for the job and you will |
| There are none. |
