| Posted by Bill on November 27, 2001 at 13:54:49: | |
| In response to Re: pin hole leaks in copper water pipes | |
I believe you want to have only one ground connection. Not all grounds are at the same voltage potential so you could be getting a current flow which causes electrolysis. Any chance the leaks are between the various grounds?
: Mike Tillery
| There are none. |
