| Posted by DeWayne on November 27, 2001 at 08:36:44: | |
| In response to Re: pin hole leaks in copper water pipes | |
: We have had 3 pin hole leaks in the water system in a seven year old home. Recently we noticed the electrical system was grounded to the cold water supply from the well. There are also two other ground points to the water pipes in the home. : Do you have any ideas about the cause of the problem? : Thanks for your help. : Mike Tillery The electrical ground to the water pipes is normal. Good luck! DeWayne |
| There are none. |
