| Posted by DeWayne on November 27, 2001 at 08:25:28: | |
| In response to Re: toilet leak | |
: I've got a very bad leak, and I think it's coming from the pipe that leads out of the wall. I bought a new valve but I can't remove the old one. The water is clean but I can't stand the floods. I have cut off the main line and this pipe continues to pump water. Help ASAP. If the valve is leaking, you can remove just the Take the valve stem to the hardware store and have The big chain hardware stores would rather sell you Hope this helps... DeWayne |
| There are none. |
