Re: Cast Iron radiator Removal
Posted by hj on November 25, 2001 at 08:08:49:
In response to Re: Cast Iron radiator Removal
If you mean you have separate supply and return mains then just cap them. If you mean the radiator has two pipes and they both connect to the same main in the basement then connect them together since the system could be designed to depend on that water returning to the system.
: I would like to remove a small radiator from a room. It is a hot water, two pipe system. Can I drain the radiator and cut and cap the feed & drain pipes; or do I need to join the pipes once the rad is removed. Tahnks in advance.
Replies to this post
There are none.
