Cast Iron radiator Removal
Posted by Chris on November 24, 2001 at 23:17:37:
I would like to remove a small radiator from a room. It is a hot water, two pipe system. Can I drain the radiator and cut and cap the feed & drain pipes; or do I need to join the pipes once the rad is removed. Tahnks in advance.
Replies to this post
