Re: Terry, or anyone else for that matter.. On demand water heaters
Posted by Joel on November 20, 2001 at 02:40:38:
In response to Re: Terry, or anyone else for that matter.. On demand water heaters
: I am building a house, and I am thinking about putting a on demand hot water heater in... Only thing that I am curious about is how much the difference in water pressure it is going to be... If anyone has any experience, or knowledge about these, would appreciate any, and all comments... : Thanks Todd, I installed a unit from Rinnai last year for my whole house and I love it. You will save enough in a few years to pay for the unit, and it should last 4x as long as a tank heater (10 yr warranty). The flow on mine is 6.3 Gal/min at up to 180,000 BTU (about 54 F temp rise). Enough for 2 showers and then some. The only time I have noticed a reduced flow at a lav is when I open the 3/4 valve on my large tub, but then, I only have a 3/4 service. (I think it is insane when plumbers install a separate tank heater just for a spa.) This unit is specd as a boiler and is used in comercial applications replacing large tank heaters for hotels with a much smaller tank. The only consideration is that it should be mounted outside for venting and 3 feet away from openings. It is freeze protected to -30 C. Other models an vent to flue or power vent. Avoid unregulated (fixed heat) units. Most are wimpy and only good for limited use such as one shower or for cabins/boats.
Replies to this post
There are none. |
