| Posted by Joel on November 20, 2001 at 01:55:50: | |
| In response to Re: Hot water heater for hydronic heat | |
Yes, you can use your domestic hot water for hydronic heating. You need to use piping to code. I recomend PEX (cross linked polyethelene). Even the 90-140 degree water will heat a room. (It is constant, comfortable heat, not a steam flash.) (Steam systems went out with those huge cast iron radiators and noise.) You need to add a thermostat for the recirculating pump (and make sure it is to code for a potable system). Some installers use a light concrete mix between the pipe in the floor, but there are systems of floor grid if you can give up 2" above the floor. Any flooring can be installed above. There are other less eficient systems where the PEX is placed in a sheet metal tray that directs the heat through a wood floor, but you need access below the floor. I don't have the links here, but there was a grid product from Korea that won a inovation award a few years ago. Super easy install. |
| There are none. |
