| Posted by hj on November 19, 2001 at 22:34:20: | |
| In response to Re: two cabins/pressure tank systems- 1 well pump? | |
There is no way to control two systems with one pump unless they are tied together in such a way that the pressure rises and falls in both systems at the same time, unless the pump controller also operates a solenoid valve to divert the flow to the system that is calling for water. In that case, besides the valve, you require a relay to isolate each system. : Is it possible to wire a single well pump to control two separate pressure tank systems in two separate cabins? Any help would be appreciated. : chris
| There are none. |
